dwdave Posted July 15, 2015 Posted July 15, 2015 I have never used the speaker output on the Galaxy Panel. Only ever sounders etc. What is the difference between the two? Thanks, Quote 'till the next question ...
al-yeti Posted July 15, 2015 Posted July 15, 2015 Speaker gives you different "speed"(whatever you call it) tones for faults or exit etc Sounder just sounds Quote
sixwheeledbeast Posted July 15, 2015 Posted July 15, 2015 A sounder makes a noise, a speaker mimics the tones of the panel for different conditions (Fire, Intruder, Entry, Chime, etc) Quote
dwdave Posted July 15, 2015 Author Posted July 15, 2015 Gotcha. Makes perfect sense. Quote 'till the next question ...
charlie6 Posted July 15, 2015 Posted July 15, 2015 It would make even more sense if the speaker or sounder is not mounted adjacent to a end station which, amongst other things, is supposedly placed in a out-of-site location. Mounting here would simply draw attention to the location of the panel. Quote
sixwheeledbeast Posted July 15, 2015 Posted July 15, 2015 It would make even more sense if the speaker or sounder is not mounted adjacent to a end station which, amongst other things, is supposedly placed in a out-of-site location. Mounting here would simply draw attention to the location of the panel. That's correct, WD's are not supposed to be mounted next to CIE for that reason. Quote
dwdave Posted July 15, 2015 Author Posted July 15, 2015 Yeah I'm all over the Wd's and CIE's. Sometimes I like to throw in some ABC's and mix it with a little 123. But .... I am planning to mount the extension speaker downstairs - probably the furthest point from the panel, and right above a PA trigger. Quote 'till the next question ...
Simlec Posted July 15, 2015 Posted July 15, 2015 That's correct, WD's are not supposed to be mounted next to CIE for that reason. Don't you just love it when they mount them in the control panel. Quote
dwdave Posted July 15, 2015 Author Posted July 15, 2015 Come on then - someone put me out of my misery. WD - Warning Device? CIE - Consumer .... EndStation? I dunno - give us a clue? Quote 'till the next question ...
Simlec Posted July 15, 2015 Posted July 15, 2015 BS Definition: Control and Indicating Equipment Quote
