dwdave Posted July 17, 2015 Posted July 17, 2015 I'm refitting a number of these that were in my old house but I have lost the round piece that sits inside the bracket and the pir screws to it. I have emailed pyronix but no response. Cam anyone suggest what to do? 'till the next question ...
Lwillis Posted July 17, 2015 Posted July 17, 2015 No don't have to use the bracket. We never normally do unless they are feeling mounted
dwdave Posted July 17, 2015 Author Posted July 17, 2015 This one is ceiling mounted. 'till the next question ...
Adi Posted July 17, 2015 Posted July 17, 2015 **** way to do it, do it properly. I really can't be ar**** with it anymore.
dwdave Posted July 17, 2015 Author Posted July 17, 2015 What is a **** way to do it? How would it be done properly? 'till the next question ...
goncall Posted July 17, 2015 Posted July 17, 2015 How would it be done properly? by those who do it day in id imagine..
MrHappy Posted July 17, 2015 Posted July 17, 2015 What is a **** way to do it? a bracket, do you need it to tie your horse up ? Mr Veritas God
dwdave Posted July 17, 2015 Author Posted July 17, 2015 I'm trying to use a bracket but im missing a key part of it. I thought Adi was going to suggest that a ceiling mount was a **** way. I certainly don't want to screw through the back of the DT straight into the wall. 'till the next question ...
charlie6 Posted July 17, 2015 Posted July 17, 2015 There are ready made mounting holes on the pir for corner or straight wall placement. It's not often that a bracket is needed except in certain circumstances. Can you mount it in the corner of a room or flat wall ? Remember to seal any other holes to prevent dust and insect ingress. Usually, the pcb needs to be removed for mounting in this way (don't lose the pcb screw)..but not always...depends on the pir.
