Hi there, first post for me here.
Basically I've had a call where customer is unable to set the alarm due to what sounds like either damaged cable or maybe it's been snipped as there are works going on close by.
It's a Honeywell Galaxy panel which I know absolutely nothing about as am very new to the trade.
Can someone tell me if it's possible programme that device off until further investigation can be made so they can set the alarms again.
Thank you
Posted (edited)
Hi, when you say you are new to the industry, do you mean you are a security installer* working for yourself?
Edited by datadiffusion
If system is setup so zones can be omitted then yes , entering user code and looking through menu for omit , it may come up with no entries, if so then you must call an engineer
Not if its a tamper, you will need to go into engineers and reprogram the circuit in question. Or fix it now
Yes man of course forgot that bit!
  • 4 months later...
