Guest toasty Posted October 13, 2004 Posted October 13, 2004 New glasses are a good idea, don't get the same ones again mate. The ones in your lovely avatar are so 1980's
Chris Teague Posted October 13, 2004 Posted October 13, 2004 Wow, wished I'd not put a track on this topic now My E Mail in box groaned It went from biscuits to light bulbs Anyone got anything to say on the original topic of ID chips & false alarms? Chris Teague (Sales & Operations Manager) Sightguard Intruder Division Covering the Isle of Wight: - Design, Installation, Maintenance & Takeover of Intruder Alarms, Fire Alarms & Equipment, CCTV, Access Control, Nursecall. Keyholding Service, Guarding & Cash in Transit. SSAIB & NICEIC Registered Tel 01983 884000 / 884440 Any comments / opinions posted could be the voices in my head speaking, but they are my opinion only and do not represent those of my employer or Company
Red Fox UK Posted October 13, 2004 Posted October 13, 2004 Hmmm.... So is nobody gonna give me a Digestive?? Red Fox | Hosting Affordable and Reliable UK Based Web Hosting
Chris Teague Posted October 13, 2004 Posted October 13, 2004 That's exactly why I didn't say "Anyone got anything to say on the original topic of Biscuits" Don't think I could have taken another three pages of light bulbs and links to their inventors, Gingernut's & Custard Creams (now there another subject) banghead banghead Oh well, I think our lads want to rip them out and EOL them on this system. This was a fairly good install and only just over a year old, met all reg's etc. Good detectors, no other obvious reasons to F/A. Sometimes best to walk away from some takeovers Pass the Bourbons Chris Teague (Sales & Operations Manager) Sightguard Intruder Division Covering the Isle of Wight: - Design, Installation, Maintenance & Takeover of Intruder Alarms, Fire Alarms & Equipment, CCTV, Access Control, Nursecall. Keyholding Service, Guarding & Cash in Transit. SSAIB & NICEIC Registered Tel 01983 884000 / 884440 Any comments / opinions posted could be the voices in my head speaking, but they are my opinion only and do not represent those of my employer or Company
Guest Posted October 14, 2004 Posted October 14, 2004 New glasses are a good idea, don't get the same ones again mate. The ones in your lovely avatar are so 1980's 27255[/snapback] And what was wrong in 80's??? Maybe you put your face in avatar and we'll see how gentlemen looks in the beginning of 21st century..
Guest Posted October 14, 2004 Posted October 14, 2004 Wow, wished I'd not put a track on this topic now My E Mail in box groaned It went from biscuits to light bulbs Anyone got anything to say on the original topic of ID chips & false alarms? 27264[/snapback] If you didn't yet notice I already told how to avoid them. Now we have a small how to make so it meets UK regulations.
Guest Posted October 14, 2004 Posted October 14, 2004 And here comes the answer from the manufacturer: The Conductors , tin stranded copper wire with no les than 7 strands of nominal diameter 0,20 , are covered with type2 or type TI1 compound pvc insulation complyng with a minimum point thickness of 0,15 mm when measured in accordance with BS 4808:Part 1 The Cores should be laid straight with the same lenght of lay to form a compact cable In case of shielded cable we should included a poliester foil and a extra alluminium foil with draining tinned copper wire The cable shall be sheathed with type 6 or type TM1 Pvc Compound compliyng with BS 6746 with a minimum point of thickness of 0,4 mm measured in accordance with BS 4808 : Part 1 The sheathing shall be continous ,semi- tubed , and shall fit closely over the cores without adhesion A rip cord with a breaking srenght of not less than 40 N is provided under sheathing to facilitate its removal The cable is supplied labeled with all the caractheristics required , included the CE marking. __ Did anyone check if it is necessary to earth casings where only extra low voltage is used?
Guest Posted October 15, 2004 Posted October 15, 2004 Wow, wished I'd not put a track on this topic now My E Mail in box groaned It went from biscuits to light bulbs Anyone got anything to say on the original topic of ID chips & false alarms? 27264[/snapback] I started a new topic in trade/controlpanels about this..
norman Posted October 15, 2004 Posted October 15, 2004 also alarm cable has a CSA of 0.2mm compared with 0.5mm of twisted pair.The twisting of the cables then adds additional CSA to the whole cable and alarm cable is more flexible and has a smaller bend radius 27184[/snapback] ehh.. CSA?? (i don't understand) you have to remeber that cat5 bending radius is given so that 100Mb/s can still go through.. 27209[/snapback] Cross Sectional Area Nothing is foolproof to a sufficiently talented fool.
Guest Posted October 15, 2004 Posted October 15, 2004 Cross Sectional Area 27485[/snapback] what is the geometrical term for this CSA ?
