Evening, few questions for you all
I have a galaxy classic panel installed for an external building at home. It has auto set enabled for mon-fri mornings. Sometimes I don't need autoset so how can I turn autoset off without having to log into engineers everytime? Also, how can I unprogramme a link? I have a strobe on an o/p programmed as strobe but I also have a link programmed so the strobe pulses in autoset pre warning but it doesn't stop pulsing afterwards when the system is set. Hope to have a reply soon, thanks.
".....It has auto set enabled for mon-fri mornings. Sometimes I don't need autoset so how can I turn autoset off without having to log into engineers everytime?..."
I can't find anything in the operator instructions which allows you to turn autoset off when it has been pre-programmed.
"....how can I unprogramme a link?..."
Re-program all links... page 98 ?
"....strobe pulses in autoset pre warning but it doesn't stop pulsing afterwards when the system is set..."
de-program the link.. do you really need a pulsed strobe in this setup ?
