sixwheeledbeast Posted August 7, 2015 Posted August 7, 2015 most fa,s caused by code problems the numpty went further into the property to phone for help, so not only confirmed once but several confirms in most cases. Exactly. Quote
norman Posted August 7, 2015 Posted August 7, 2015 He had the code to switch it off? Quote Nothing is foolproof to a sufficiently talented fool.
goncall Posted August 7, 2015 Posted August 7, 2015 I have to disagree, I have to disagree on your disagree 95% of fa's in my experience were from detection normally one trip,misops be it on entry or exit were a small part Quote
al-yeti Posted August 7, 2015 Posted August 7, 2015 Fas I seen are mostly active8's or no Dt in kitchen..... Quote
PeterJames Posted August 7, 2015 Posted August 7, 2015 He had the code to switch it off? He was using the building to plane doors and fit the locks, he was storing his tools in there so I gave him a code that switched off that out building. its only monitored when the system is full set so doesnt need a fob for the outbuilding while the system is unset. Quote
norman Posted August 7, 2015 Posted August 7, 2015 But the cod would unset when the full system was set? *code Quote Nothing is foolproof to a sufficiently talented fool.
PeterJames Posted August 7, 2015 Posted August 7, 2015 Area code for the out-building only it wont work if the system is fully set and I will switch it off when the builder is finished. Quote
al-yeti Posted August 7, 2015 Posted August 7, 2015 Area code for the out-building only it wont work if the system is fully set and I will switch it off when the builder is finished. Get him to straighten the rear dummy while he's there Quote
james.wilson Posted August 7, 2015 Posted August 7, 2015 prox was introduced as a cheap way to keep things the same, shunt locks should be preferrred imo Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
sixwheeledbeast Posted August 7, 2015 Posted August 7, 2015 Get him to straighten the rear dummy while he's there Someone's put a swimming pool in the way... Quote
