Gemini Posted August 5, 2015 Posted August 5, 2015 I hear these strange noises, and put my head out of the window and they sound like they are coming from the intruder bell. It sounds like a smoke alarm tone, but I have never heard this before. There is a possibility that it could be coming from the roadside or otherwise. I have entered the engineer's programme on The ADE Optima Plus 2, conducted a bell test, turned FCU off, and nothing has changed. There is no battery in the panel, and the bell battery is likely to have worn out (installed in 90's). https://youtu.be/cKWVqqEklCM Quote
MrHappy Posted August 5, 2015 Posted August 5, 2015 assuming its the alarm, an old siren running at low voltage? Quote Mr Veritas God
Gemini Posted August 5, 2015 Author Posted August 5, 2015 It was a refuge smoke alarm at the roadside with the screw, dryline plug, and cut cables on it. Quote
charlie6 Posted August 5, 2015 Posted August 5, 2015 I've been called out to these in the past...strange noise coming from the panel....duff smoke detector situated nearby. Sometimes this low droning noise is precisely what Mr. Happy says..seen that a few times too... why isn't there a standby battery in the panel ? Quote
Gemini Posted August 5, 2015 Author Posted August 5, 2015 The system is unserviced in the house and we don't use it really anymore because people are usually in, with a dog. The battery itself is like from the 90's, and was only giving half of the power needed. There have been faults with the system before where it would suddenly activate and the code would default itself. It only happened once, and was like the day after I defaulted it. Quote
al-yeti Posted August 5, 2015 Posted August 5, 2015 (edited) Like the old scantronic 9800 Never seen the optima default itself Edited August 5, 2015 by al-yeti Quote
Lwillis Posted August 5, 2015 Posted August 5, 2015 On 05/08/2015 at 14:11, al-yeti said: Like the old scantronic 9800 Never seen the optima default itself Seen loads of optimas default themselves and a few with the resistor issue aswell. Normally point it out to customers on a service Quote
Gemini Posted August 5, 2015 Author Posted August 5, 2015 Hi, What is 'the resistor issue'? The Lynteck Nexus 8 has a default routine of just disconnecting power (mains and battery), which has defaulted for having a low battery. Quote
Lwillis Posted August 5, 2015 Posted August 5, 2015 On 05/08/2015 at 18:28, Gemini said: Hi, What is 'the resistor issue'? The Lynteck Nexus 8 has a default routine of just disconnecting power (mains and battery), which has defaulted for having a low battery. Resistor behind the keypad which controlled the voltage for the battery. Resistor burns out over time and over charges the batteries. Quote
Gemini Posted August 6, 2015 Author Posted August 6, 2015 Our system uses an external keypad. I do have a couple of other questions though. Whilst the panel was in the engineer programme, I had the lid off, which was fine, but when I unscrewed the bar, an alarm condition was triggered, which had to be reset. I connected what appeared to be a loose/spare core into a central junction block, which I think is the global tamper. I then removed it again, and the strobe light now doesn't seem to work. If you are curious why I conducted this action, it was due to the faults referenced earlier in the post, thinking that the loose core might be the problem. Quote
