Hi,
using Ivms 4200 from Hik, the client get a " abnormal recording" windows popping up at random . Footage is there and exploitable but this message seems to come back every now and then. Any ideas?
Also on the app, it appears that they can only access around 3 days of footage at a time, sometimes not the most recent three days?
NVR is a 7600 series with 4 ds2112.
have any of you wise old owls got any knowledge you'd like to share with a fellow installer/
Merci bien.
I'm not regarded as the 'main runner' in this field, but I would guess (working on lower end equipment) that you have a faulty device, disconnect to only the bare minimum and test again.
  • 1 month later...
