norman Posted August 14, 2015 Posted August 14, 2015 But wireless is already available so it won't exactly replace EOL... Semantics Quote Nothing is foolproof to a sufficiently talented fool.
james.wilson Posted August 14, 2015 Posted August 14, 2015 Do you fancy fitting 8 resistors and using 10 cores for a detector in the future or a bus device on 2 wires? Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
al-yeti Posted August 14, 2015 Posted August 14, 2015 You speak with forked toungue , why 8? Hkc data bus works well though Quote
sixwheeledbeast Posted August 14, 2015 Posted August 14, 2015 Do you fancy fitting 8 resistors and using 10 cores for a detector in the future or a bus device on 2 wires? I see little time difference in wiring two cores or four cores TBH. Doubt detectors will be asked to do that many statuses. EOL will not disappear overnight. I think IP could be another option in the future. Quote
al-yeti Posted August 14, 2015 Posted August 14, 2015 Ip expensive though? Bus makes sense each component with an Id , addressable fire panels already have it , and some intruder have a type of data , although needs a third core Quote
sixwheeledbeast Posted August 14, 2015 Posted August 14, 2015 Possibly but think about the labour saving of using existing infra. I don't understand what you mean about a third core tho? Quote
al-yeti Posted August 14, 2015 Posted August 14, 2015 (edited) Ie hkc uses data bus pirs, positive, negative and data core You can star it in any direction, loop it as long as the third data core is connected That word keeps popping up "hkc" Edited August 14, 2015 by al-yeti Quote
norman Posted August 14, 2015 Posted August 14, 2015 It's not a word. Quote Nothing is foolproof to a sufficiently talented fool.
goncall Posted August 14, 2015 Posted August 14, 2015 (edited) That word keeps popping up Edited August 14, 2015 by goncall Quote
RichL Posted August 14, 2015 Posted August 14, 2015 I'd put money on anything wired (for detection) being a technological dead end. Lithium battery power is moving fast allowing it to be incorporated into many different platforms and production is ramping up in anticipation of this, examples of this change are all around you in the media - hoovers being the obvious one. I think 3-5 years time we'll be fitting w'free dtecs as standard with all parameters accessable and controlled via the panel/remotely with mesh tech as standard too. Even on new commercial installs. Quote Originally said by Charles Babbage On two occasions I have been asked [by members of Parliament], 'Pray, Mr. Babbage, if you put into the machine wrong figures, will the right answers come out?' I am not able rightly to apprehend the kind of confusion of ideas that could provoke such a question.
