  On 14/08/2015 at 15:13, datadiffusion said:
But wireless is already available so it won't exactly replace EOL...
Semantics
  On 14/08/2015 at 17:04, jameswilson said:
Do you fancy fitting 8 resistors and using 10 cores for a detector in the future or a bus device on 2 wires?
I see little time difference in wiring two cores or four cores TBH.
Doubt detectors will be asked to do that many statuses.
EOL will not disappear overnight.
I think IP could be another option in the future.
Ip expensive though? Bus makes sense each component with an Id , addressable fire panels already have it , and some intruder have a type of data , although needs a third core
Posted (edited)
Ie hkc uses data bus pirs, positive, negative and data core
You can star it in any direction, loop it as long as the third data core is connected
That word keeps popping up "hkc"
Edited by al-yeti
I'd put money on anything wired (for detection) being a technological dead end. Lithium battery power is moving fast allowing it to be incorporated into many different platforms and production is ramping up in anticipation of this, examples of this change are all around you in the media - hoovers being the obvious one.
I think 3-5 years time we'll be fitting w'free dtecs as standard with all parameters accessable and controlled via the panel/remotely with mesh tech as standard too. Even on new commercial installs.
Originally said by Charles Babbage
On two occasions I have been asked [by members of Parliament], 'Pray, Mr. Babbage, if you put into the machine wrong figures, will the right answers come out?' I am not able rightly to apprehend the kind of confusion of ideas that could provoke such a question.
