norman Posted August 29, 2015 Posted August 29, 2015 You tease you . Quote Nothing is foolproof to a sufficiently talented fool.
charlie6 Posted August 29, 2015 Posted August 29, 2015 It's a while since I last installed one of these, but yes, when the module detects the loss it will sound a local alarm (well, it used to once upon a time). Quote
norman Posted August 29, 2015 Posted August 29, 2015 Dont think that was the question, by delivered I think Admin meant transmitted. Quote Nothing is foolproof to a sufficiently talented fool.
charlie6 Posted August 29, 2015 Posted August 29, 2015 Norman:- "...Dont think that was the question, by delivered I think Admin meant transmitted..." Same difference, but you won't believe me anyway..your in the group that call me a bull******, liar and blagger. So it makes not the slightest difference what I say as far as you are concerned does it ? Quote
james.wilson Posted August 29, 2015 Posted August 29, 2015 it doesnt but can u please just answer the odd question without one Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
charlie6 Posted August 29, 2015 Posted August 29, 2015 Which question would you like me to answer Admin ? Quote
james.wilson Posted August 29, 2015 Posted August 29, 2015 Any without you answering it with another not to me yet just what ive read. Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
charlie6 Posted August 29, 2015 Posted August 29, 2015 Admin:- "..just answer the odd question without one.." I'll run back through the posts on this thread. However, When I am interrogated it is obviously incumbent upon me to establish whether the question contains arbitrary nuances..It is not my desire to create, nor become involved in, what may be perceived as 'petty squabbles'. Quote
norman Posted August 30, 2015 Posted August 30, 2015 I just hear this now... Quote Nothing is foolproof to a sufficiently talented fool.
GalaxyGuy Posted August 30, 2015 Posted August 30, 2015 OK. As Admin points out quite correctly, nothing will happen on a line fail. However, if you fit a Line fail module at the control panel this shall cause a local alarm when the line is cut.. Having said that, I haven't seen one of these modules in any of the trade warehouses for several years. No need for additional modules with the Galaxy G2. The panel will monitor the PSTN line input for voltage and provide a local alert if there is a problem (as per JW). The panel will also assert the fault output if you want this to trigger a separate signaling method. Third party multi-path devices can also be installed in the panel, but the G2 has a limited power output, so it's a push for the G2 system to drive system peripherals plus a combined GSM/Ethernet device. A UPS based Broadband/GSM router is also an option for single path devices where the fixed broadband line may be susceptible to sabotage and more than a line fault needs to be detected. Quote
