Any ideas what the correct settings are for SMS notifications on a flex?
Doesn't seem to want to work the work the g2's do with sending sia level 3.
Tried the wizard and it didn't work .
It's not something I've tried on the Flex V3.
I go directly to Ethernet or GSM with the Flex, as TAP is very old/limited technology these days.
Do you have the site saved under RSS ? Send me the template and I'll check it against my test panel.
Yeah customer only wants SMS so its either using the panel modem or fitting an SMS dialler.
Don't have it on RSS but if you can let me know what it should set up as I'll try it.
56.3.1.3.1   Setup the PSTN message centre No.
56.3.1.3.2   Set for TAP
56.3.1.3.3   Leave password blank  - Vodafone doesn't use a password in their protocol, as they charge per 17p per answered call.
56.2.5  - Give the site an ID
56.2.1 to 3  - Up to three mobile numbers
56.2.4 to set up the triggers.  Remembering that the 'Mode' enabled the actual trigger.
