Honey-Well Posted September 2, 2015 Posted September 2, 2015 Were getting an alarm enginer to do some updatea and I would like clarification of honeywells g2 zone programs. Our property has a front door, leading to a small vestibule, which then leads to a second 'internal' door which leads into the hall. The keypad (a MK7) is located in the vestibule, between those two doors. The vestibule also contains a PIR. When leaving the property, we want to terminate the exit countdown on closing the front external door (or initiate countdown on opening the door) and therefore the front external door has been specified as a'final exit zone.' However, we also want the vestibule PIR to be active during part set and night set modes on our G2-20 panel. We want that PIR to trigger the entry/exit process when we enter the vestibule to disarm via the keypad in the morning. As this 'morning disarm ' process doesn't require us to open the front external door (programmed as final exit), does this mean an installer cannot programm that PIR to 'entry/exit.' Doing so would result in an instant alarm as the external door (final zone) had not been opened beforehand and therefore that PIR would be functioning as an intruder zone. What would be the result of programming that PIR AND the external doors mag-contact, both as 'final zone.' Can PIRs even be used as a final exit zone. Apologies for the horrendous grammar. Blame it on stubby fingers and a small phone. Quote
Honey-Well Posted September 2, 2015 Author Posted September 2, 2015 My understanding is that entry-exit zones are 'instant' UNLESS a final exit /entry device has been triggered first (or the user is leaving the property.) Therefore, that PIR will instant-alarm if I enter the vestibule in the morning. Quote
Vince8282 Posted September 2, 2015 Posted September 2, 2015 The vestibule PIR can be programmed as final exit too in part guard. Depending how big a vestibule you have my concern would be false alarms caused by opening the front door and the PIR activating before the contact on the front door dropped out. Quote Practice in the morning, practice at night. Practice in the evening, until you get it right. Only make sure you are practising in the right way at the right time for it.
al-yeti Posted September 2, 2015 Posted September 2, 2015 The vestibule PIR can be programmed as final exit too in part guard. Depending how big a vestibule you have my concern would be false alarms caused by opening the front door and the PIR activating before the contact on the front door dropped out. It should work fine, pir problem might occur if it's something like active 8 Quote
james.wilson Posted September 2, 2015 Posted September 2, 2015 if you program it as final it wont work. if you proram the pir as final triggering it will cause it terminate the setting process and you may still be there or in the hallway. program it as exit and when the galaxy is part set it will make the exit zone an it will becvome an entry zone in part set Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
Honey-Well Posted September 2, 2015 Author Posted September 2, 2015 Thanks all, this help is great. if you program it as final it wont work. if you proram the pir as final triggering it will cause it terminate the setting process and you may still be there or in the hallway. program it as exit and when the galaxy is part set it will make the exit zone an it will becvome an entry zone in part set Just had a look at the programming manual James and I believe that what you've mentioned is my best option. So my installer can program the front door contact zone as 'Final Zone' and specify it also as an terminate entry/exit zone. But, program the PIR to entry/exit (without the terminate command.) If I walk into the vestibule, having not opened the front door, the PIR will initiate the entry/exit tones first? Quote
charlie6 Posted September 2, 2015 Posted September 2, 2015 Have a chat with your engineer about the possibilites of putting a push button (won't bother explaining), it's not more that a door bell press outside the front door and weigh up the options with him, he is the best person to advise you on this otherwise the issue may result in you being more confused. Quote
al-yeti Posted September 2, 2015 Posted September 2, 2015 if you program it as final it wont work. if you proram the pir as final triggering it will cause it terminate the setting process and you may still be there or in the hallway. program it as exit and when the galaxy is part set it will make the exit zone an it will becvome an entry zone in part set On timed set? Quote
james.wilson Posted September 2, 2015 Posted September 2, 2015 In part yes Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
al-yeti Posted September 2, 2015 Posted September 2, 2015 (edited) On timed set it won't terminate via the pir, as I thought final exit only terminates if no time set Edited September 2, 2015 by al-yeti Quote
