a1steve Posted September 7, 2015 Posted September 7, 2015 look at getting a hikvion dvr i have priced them up and this is the prices I have found hikvision DS-7216HWI-SH with 2tb will cost £324 hikvision DS-7216HVI-SV/A with 2tb cost £195 that is the older modal out of the two. has anyone used the hikvison dvr and witch one would you recommend using its only for a house CCTV Quote
ACDC Security Posted September 7, 2015 Posted September 7, 2015 Only ever used the HIk NVR Very good and if a new install I would go for the NVR and 2 MP ip cameras Good mobile app And free DDNS to get around the need of a static ip for remote monitoring Quote
petrolhead Posted September 7, 2015 Posted September 7, 2015 I would go for the newer 7216 hghi-sh then you can reuse any analogue cameras you already have, and upgrade to 1080p hd-tvi cameras on any channel plus you can add an additional 2 ip cameras. I might have one in the workshop you can have for the same price as the old analogue hwi one. Quote
craggy Posted September 11, 2015 Posted September 11, 2015 (edited) Same as ACDC, I have only really used the IP range and as such the NVR's but it is great kit for the cost If its a new install (i.e. no existing cameras) I would definitely go down the IP route rather than analogue, being the newer technology. I know there is a price difference between them but for the actual cost its a good investment. You even get PoE ports on some of the NVR's which really simplifies the install by just needing a cat5 or 6 cable and no power, depending on distances. But that's just my take Edited September 11, 2015 by craggy Quote
