Guest Paul Posted August 17, 2003 Posted August 17, 2003 Having moved house I have attempted to change my Manager Code for my panel but unfortunately my manual does not have the note that warns that manager codes cannot start with zero - the latest ones do I see from Scantronics website! The system appeared to accept the code but now the new code doesn't work and nor does the old one or even parts of the new one. Does anyone know how I can get back to a point where I can reset the manager code having entered a code beginning with zero?
Service Engineer Posted August 17, 2003 Posted August 17, 2003 REFRESHING THE NVM (9600) If the user and/or engineer codes are lost, or you wish to revert to the standard factory default codes: 1. Remove all power - both mains and battery. 2. Remove the NVM chip IC8 (above the large microcontroller chip). 3. Power up the panel - battery first then mains. 4. Refit the NVM chip. The panel will now load the standard factory default codes. 5. Re-program the panel with all the installation settings. Obviousely refreshing the NVM should be your last resort. The new Engineer code will be 07890 The new Managers code will be 1234 ........................................................ Dave Partridge (Romec Service Engineer)
Service Engineer Posted August 17, 2003 Posted August 17, 2003 Initial Start Up Having programmed all the keypads in the system, power up the control panel, battery first, then mains. Close the control panel lid and proceed as follows: The keypad display shows: 00:00 MON 01 JAN 1. Key in 1234 (the default User Code). The display shows: SYSTEM UNSET followed by : 00:00 MON 01 JAN (the displays may vary depending on system status) 2. Key in 07890 (the default engineer code). The display shows: RESET SYSTEM? YES/NO 3. Press NO. The display shows: PROGRAM SYSTEM? YES/NO 4. Press Yes. Note: If after pressing ........................................................ Dave Partridge (Romec Service Engineer)
