ElecTech Posted September 14, 2015 Posted September 14, 2015 Hi, A client has Paxton Net2 installed and currently uses HID ICLASS R30 readers on all sites... I'm used to using PAC and have only ever used there readers and have never used any type of 3rd party readers. 1. Would Paxton's own HID reader be compatible with the Net2 V.4 (the Paxton reader is cheaper than the 3rd party) 2. Why would a 3rd party reader be used in the first case. I believe this was a brand new install & not a takeover. 3. Would it be as simple as disconnecting an old faulty HID iCLASS reader and following the wiring diagram for the Paxton's own reader? Old reader - https://www.hidglobal.com/sites/hidglobal.com/files/resource_files/iclass-r-series-c-readers-ds-en.pdf New reader (hopefully) - http://www.paxton.co.uk/productsearch.asp?id=&salescode=345-220 Thanks. Quote
MrHappy Posted September 14, 2015 Posted September 14, 2015 personally I'd replace the iclass reader like for like, I'd assume the Paxton HID reader would read the HID token their using, but theres always a chance of weirdness ? reasons for 3rd party readers ? use of the same tokens with a clocking in system or indruder alarm or they choose not to use paxton or they can buy HID cheaper Quote Mr Veritas God
ElecTech Posted September 14, 2015 Author Posted September 14, 2015 Believe it or not the HID reader they currently use is £60 more. What "weirdness" could occur and why? They use ID cards but I'd of thought if it's a HID card then either reader will work. Sorry for the basic questions but I don't know enough about the ins and outs of the technology that the readers use. Quote
MrHappy Posted September 14, 2015 Posted September 14, 2015 There's different HID formats, We know the R30 reads the tokens on site, The paxton reader will probably work, Quote Mr Veritas God
ElecTech Posted September 14, 2015 Author Posted September 14, 2015 Ok , might take one to site as a tester. Quote
ElecTech Posted October 15, 2015 Author Posted October 15, 2015 (edited) So I went to site with the below reader as a test dummy... http://www.paxton.co.uk/products.asp?strStage=specification&strFamily=net2&strProduct=345-220&strGroup=group-05117 I found the following... I connected the reader to a Net2 Plus into reader 2 output. I connected up all 8 wires (two wires were left out from the existing reader Amber LED, Media Connect), we also tried it without these wires in. The reader looked as expected (red and green lights on) and when swiped a pass on the other side the reader turned from green to red as it should, yet would not read any HID cards... Attached is the door setup, I've been told the cards are wiegand 26 bit iclass cards... Is there a quick solution or shall I go like for like? Edited October 15, 2015 by ElecTech Quote
datadiffusion Posted October 15, 2015 Posted October 15, 2015 (edited) Perhaps Paxton 'Univeral' was sold via Advanced Access as 'own brand' for much better pricing than Paxton 'ordinaire'. I use these regularly on an 'all wired' job. Much better margin on fobs too that way. Always turn up with Paxton Universal part nos and manual inside the box. Edited October 15, 2015 by datadiffusion Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands
