Galaxy G3
whizzer
If the panel has been locked down properly, then you will not be able to connect with RSS. The virtual keypad 'backdoor' is not a back door and the pin should also have been changed if the panel is locked down.
Other than that, it requires specialist equipment to interface with the Atmel CPU. Easier to display the zones, note them and then default.
Link to comment
Share on other sites
