BveshPatel Posted September 20, 2015 Posted September 20, 2015 Hi All Control Panel 9751EN Keypad 9943 Prox Wireless Expander RFX08 PIR Scantronic 714r Passive Infrared Detector and Transmitter x4 Door Contact Scantronic / 734r Wireless Door Contact x2 Does anyone know why the tamper fault wouldn't be activated when I remove the lid from a PIR and a door contact. Quote
datadiffusion Posted September 20, 2015 Posted September 20, 2015 (edited) Do they work normally on alarm? If it was just the door contact, I would have a simple answer; many installers, when using external contacts, forget to program the actual tamper of the actual tx unit itself as a 24 or tamper only zone. i.e its possible to program an external mc contact, by tampering on said external contact to program, and not have the actual on-board tamper registered with the RFX at all. Edited September 20, 2015 by datadiffusion Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands
BveshPatel Posted September 20, 2015 Author Posted September 20, 2015 Thank you for your reply. The contacts do work on normal alarm. The Door Contact used as Final Exit and the PIR is on Entry route. Currently I have removed batteries from both as they were low and I need to replace them, however I am still able to set the the alarm without them which is making me wonder why that is as I have changed nothing in the programming? Quote
datadiffusion Posted September 20, 2015 Posted September 20, 2015 1 way kit such as scanny will not care if the sensors disappear if tamper is also not working - it won't be until the next missed poll it gets 'noticed'. I would re-learn and see what happens. Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands
BveshPatel Posted September 20, 2015 Author Posted September 20, 2015 Please explain what you mean by next poll? Quote
datadiffusion Posted September 20, 2015 Posted September 20, 2015 With one way kit the panel relies on the transmitter sending a signal at a fixed interval to know it's still there - to stop someone removing the entire thing (without activating the tamper) and putting it out of range, for one thing. This is not always that often, but the panel will be expecting to hear from the transmitter at some point. When it doesn't 'poll', an error should be shown at the panel, on a scanny this would be a 'supervision' fault (although it can (foolishly) be disabled, on iOns at least). This isn't to be confused with alarms (CC and tamper) or low battery signals. Hope this helps! This is why 2 way or mesh kit is so much better. Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands
BveshPatel Posted September 20, 2015 Author Posted September 20, 2015 Thanks for the explanation. Am guessing that means that on my current alarm system it doesn't poll and therefore doesn't recognise that there are two detectors missing hence why the alarm can still be set and they can be removed without the system recognising there is a fault. Also just to confirm this is also the reason they didn't go into tamper when I opened them up to remove the battery. Would I be able to program them for tamper as well as Final Exit and Entry route once I replace the batteries by asking the RXF08 to re learn the devices? Quote
datadiffusion Posted September 20, 2015 Posted September 20, 2015 It polls infrequently so it will be a matter of time (up to 4 hours?) before it notices they are gone. If set a supervision (poll) fail will usually cause a full alarm, depending on configuration. The tamper issue is quite separate - but the fact it is not working is why the alarm can still be set. A re-learn might be in order, then just see if the tamper works right away. Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands
BveshPatel Posted September 20, 2015 Author Posted September 20, 2015 Thanks I'll re-learn the devices when the batteries are replaced and report back with my findings. Quote
datadiffusion Posted September 20, 2015 Posted September 20, 2015 OK, that would be the best thing to try 1st. Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands
