Hi,
I was recently called to a customers house for a phone line faullt, I thought perhaps they had changed their telephone provider and was a simple fix. however, when i arrived i noticed the keypad looked unfamiliar.
I checked the control panel which was a Honeywell Ademco XPC which i thought strange as i have worked on those systems before but never with that keypad. I later discovered that the keypad is for the Honeywell Vista?
So basically i reset the engineer code and tried to clear the line fault but have had no success. I cant seem to find a manual that ties these two together. Following the XPC manual doesnt seem to work. As far as i understand to clear the line fault on the XPC you type 7 for group 7 then 7 again for option 7 and 0 to disable the line fault but obviously that isnt the case with this bugger!
Has anybody had experience with these systems and if so could explain where i am going wrong.
Any help would be much appreciated. Thanks.
Russell
I believe what you are looking at is the accord with the rf keypad, it looks similar to the keypad above but the programming is the same apart from the rf detectors
