Posted (edited)
surely the other issue is what do the units need power wise to function as that may well vary from equipment manufacturer.
then given that the performance of the batteries varies significant based on the power they are drawing, so how much power does the wirless units draw, then you could get a better idea of which battery to opt for, but lower draws would suggest duracell or panasonic.
the right battery would be based on how it handles the demand from the device it is in, duracell seems consistantly good on all these test curves?
Edited by secureiam
a volt check means nowt, you never did that on the sla as a good test. Depends on the gear experience will out.
Sorry but can you expand about the service level agreement? Why wouldn't a volt test give a good indication?
Other than testing amps what else can you possibly do?
How would you best test a PIR battery then?
We dont, for the reasons above, we replace lithiums acording to our procedures and without testing
Originally said by Charles Babbage
On two occasions I have been asked [by members of Parliament], 'Pray, Mr. Babbage, if you put into the machine wrong figures, will the right answers come out?' I am not able rightly to apprehend the kind of confusion of ideas that could provoke such a question.
I have found batteries of all types, descriptions and manufacturers to be like lamps they can last a long time or a short time and with wireless stuff when monitored gives an advanced warning. Even then when the sun comes out what appeared to be a failing battery has been recovered by the system until the next cold spell. What we tend to do is use the ones we find to be best as the above chart indicates and of course the use and therefore drainage of the battery will dictate to a great degree how long they will last. E.g. on the wireless sounders from Texecom I saw the note about the life of the batteries can be between 2 years or 4 or 5 years depending if you enable the "comfort" led's or not. If you do continuous bell testing this too will reduce the life of them.
My biggest gripe about radio/wireless stuff is battery life. I see it as the weakest link in the security of the system even if the system proves to be great when working properly.
Practice in the morning, practice at night. Practice in the evening, until you get it right.
Only make sure you are practising in the right way at the right time for it.
Yep, I had the old 'recovering battery' problem on one where service had been refused the previous year, and in failing it gave several 'low battery' reports.
My theory is that the frame was quite thin, and right in the sun on the reverse, so it kept heating up on warm days and the voltage went high then low again.
