Why's that, please?
If there's 6 and 5 seem OK, why would 1 fail?
The temptation is to try pulling a bit out of the wall, cutting a few inches off and testing again, but the break could be anywhere is a cable 40 feet long, so it's nonsense really.
It just seems so strange to me that a single core would fail in a sheaf of 6.
Because the rodents aren't always hungry enough to finish it all, but once they've started they do often come back and more cores will drop.
Also when a cable has been scagged on installation, damaging the insulation, and takes years to break down. I used to see a lot of single-pole
T+E failures like that, where presumably the cables has been strong-armed into a cavity.
Soldering won't do Jack unless you didn't loop them correctly at PIR end first time
Lol thanks my English + android gets the better of me
+rodent(1)
