Hello,
I have wired an extension and been asked to add a couple of PIR's and Door contacts to an existing Bells only system its a Scantronic 9651.  There are not enough zones present in the panel so have added a 9954 expander.
Now the problem is that I cant find the extra zones, The system has 2 keypads, one with no link the other with id 2 link.  The 9954 has no link set for id.  Do I need to kick start the panel? will this delete config or passcodes?
I am expecting the extra zones to appear as zone 9 onwards as the id is not set in the expander.  I know the Menvier panels can be asked to rescan the system hardware, is this possible or nescessary on the 9954?
Any advice would be much appreciated.
Thank you
Dave
