Yes it does, Connect it to the PGM output and configure it as required
All panels will accept a speech dialler, connect to either the +ve or -Ve output,
Make sure you choose the correct polatity on the on the dialler, usually by a jumper or within the programming
Posted (edited)
The dialler takes an input from whatever device you choose to connect it to-one just has to have a little common sense.
Edited by Rulland
Most diallers factory set to negative trigger so connecting to your bell trigger will also work if you don't know how to programme the pgm output (unless it's the same on this panel)
