Hi
Need some help.
My panel flashed +BAT MIS today. First time its ever shown this and I looked up advice and it suggests a faulty battery.
I have the engineering code etc and pretty conversant with what to do to change the battery however I don;t know which battery to buy?
The manual suggests a 12v 7amh battery with a plastic box and 12v 17amh for a metal box?
When reading the installation guide on connecting the battery is says a min can be 12v 7amh but when reading the Honeywell site it says for a 2-20 you need 12v 12amh min?
What minimum should I use? I see Screwfix has 7amh but I have to search wider to find a 12amh.
The current battery in the unit was installed in 2007 and is a Texecom 12v 18ah.
Thanks
its ok I called my original installer and he recommended anything up from 7amh but for Grade 2 cert which mine is 17amh so I'm going to pick one up.
Found out what's in there an replace like for like would be sensible.
So if it's incorrect just follow suit?
We are talking DIY help here. Seems sensible advise if there has been no issues.
I would hope the system was installed correctly.
Do I really need to have this sort of disclaimer for every DIY post?
Obviously the ideal solution is have an approved installer service the system, but that wasn't the question.
