Optima XM6
Guest SimonR
Guest anguscanplay
OK COOL
I NEED TO REPLACE MY PIR SENSORS AS THEY ARE ON TO NEARLY 20 YEARS OLD AND NOT ALL WORKING. ALSO I NEED TO REPLACE MY SIREN AS THIS TO IS NOT WORKING. DO I NEED TO ENTER ENGINEERS MODE AND IF SO HOW.
SPEEDY
thats the same question as last night so its the same answer ( do us a favour and turn off the caps lock its very loud )
if you need to ask how do i change my pir sensors then i would recommend an engineer - even more so for the replacing of the siren
have a look through the forum using the search button at the top of the page there have been many many people with the same questions as you have and you may find an answer there
angus
  • 2 weeks later...
Just moved to a property with an Optima XM6. I have a code and we use the alarm at the moment, but we do not have any service / user manual. I need to know if the system can be zoned so it is not activated by our cats moving about in the kitchen - for instance. Any ideas?
Thanks in advance
Guest anguscanplay
Thanks in advance
my advice - get a service call booked with a local alarm firm,make sure the user code is/has been changed since the previous occupier moved out and consider pet tollerant scanners as an alternative to zoning the system off
angus
  • 2 weeks later...
  • 2 weeks later...
Hi
I have just moved into a new house and the previous owners have not left any documents about the Alarm. We use it at the moment but wish to change the code, so can you please forward a pdf of the user manual for an Optima XM6 on my email id as soon as possible.
Thanks.
  • 3 weeks later...
Hello,
I bet you guys are getting sick of this, but I too find myself in the position of having moved into a new house with no manual for the Optima XM6
Thanks
John
MODS - It won't let me upload PDF Files as attachments,
cheers
Dean
Dean Wholey
NCC
Dean.Wholey@Ntlworld.com
  • 3 weeks later...
Hello!
Guess what?! I too have just moved into a new house with an Optima XM6 system and no instructions or manual left for me. I want to reset the alarm code and generally figure out the system
Many thanks!
