Hi
Added a extra keypad to a euro mini panel , powered panel back up alarm sounded , entered code into original keypad wouldn't silence alarm
Thanks for any comments
I installed system with one keypad originally address 00 they wanted second keypad so powered down panel added keypad , powered back up alarm sounded entered code into first keypad wouldn't do anything , new keypad was blank and wouldn't let me enter address
You have to address 2nd keypad as 01 and go into menu to assign keypads and make sure address 01 is set to keypad not reader. Usually hold down the D key to get into keypad menu on keypad
Second keypad won't let me address i can't get into keypad menu , doubled checked all connections keypad backlight is on just blank no text
  • 2 weeks later...
If you can not get the keypads menu up by holding the D key, you may have knocked the screen contrast pot on the back of the keypad.
