Hi
I have recently bought a Risco Lightsys2 system to replace my existing system. (detectors wired independently with 6 core cable)
I can see the PIRs are now EOL however the PIR's I have are standard 6 contact Risco RK500q.
Any help would be really helpful.
Thanks Mike
Hi, use N/C (01) for zone 1-7 for alarm contact and zone 8 for common Tamper (for Z 1-7).
You can view  this is also in the installation manual ?
Good luck.
Termination
Termination
The Termination menu enables you to program the connection type used for each of the system's zones. The actual (physical) termination for each zone must comply with that selected in the zone termination menu
N/C
Uses normally-closed contacts and no terminating End-of-Line Resistor
EOL
Uses normally-closed (NC) and/or normally-open (NO) contacts in a zone terminated by End-of-Line Resistor.
DEOL
Uses normally-closed (NC) contacts in a zone using End-of-Line Resistors to distinguish between alarms and tamper conditions.
N/O
Uses normally-open contacts and no terminating End-of-Line Resistor.
It was not quite right with Paste/cut, this is maybe more clearly.
Quick Key           Parameter
212 5             Termination
01                           N/C
02                           EOL
03                           DEOL
04                            N/O
Register a new account
Sign in
