Prodigious Posted November 17, 2015 Share Posted November 17, 2015 I have recently installed a advanced addressable fire panel which worked fine....until I fitted the network card for a repeater panel! Soon as I fitted the card the panel blew Quote Thrones Link to comment Share on other sites More sharing options...
al-yeti Posted November 17, 2015 Share Posted November 17, 2015 What model? Few companies using word advanced Quote Link to comment Share on other sites More sharing options...
antinode Posted November 17, 2015 Share Posted November 17, 2015 Are you trying to hot plug the card on? IE with the panel powered up? Should always down power when making hardware changes. Check you have the pins aligned correctly, too. Could potentially be a dodgy network card if it's the same one. Quote Trade Member Link to comment Share on other sites More sharing options...
morph Posted November 17, 2015 Share Posted November 17, 2015 It's always best to fit cards with the panel powered down, if it blew as soon as you plugged them in I would suggest a short across a couple of the pins. Quote Link to comment Share on other sites More sharing options...
Shaunb1905 Posted November 17, 2015 Share Posted November 17, 2015 Never had this problem but I always add them with the panels off Quote Link to comment Share on other sites More sharing options...
sparky999 Posted November 22, 2015 Share Posted November 22, 2015 As everyone else is saying fit any card with the panel powered down Quote Peter Robinson Freelance M:07889038650 Link to comment Share on other sites More sharing options...
