Hi
We ordered a HD-SDI PTZ for the sole purpose of sending video to a HDMI projector.
We also purchased this converter box http://www.amazon.co.uk/Ex-Pro%C2%AE-SDI-HDMI-Mini-Converter/dp/B00ATQ26M0/ref=sr_1_1?ie=UTF8&qid=1447796112
When we connect the camera to the converter box the SDI lock light flickers but we get no picture on the screen.
We know the converter is 100% working so that can be rules out as being faulty.
We don't have the a HD-SDI DVR to plug the camera in to test if it is working so is there anything else we can plug in to see if it is outputting video?
I had to bite the bullet & buy a tester as my analogue only tester is now redundant so if you do a lot of installs, buy a meter & check it that way.
What's the make/model of the camera & where'd you buy it? Can you get help from the supplier?
How about doing it this way... connect it to a HD-SDI DVR then feed the projector from the DVR but only showing that channel?  If your client is not bothered about recording you could buy a barebones HD-SDI DVR for about £80 plus VAT trade & send the converter back...?
