Hi. I'm living at my Nans house. She has not used the alarm for about 5 years. I tried to set the alarm yesterday with what I thought was the code, however the internal alarm went mad and also the alarm on the keypad went mad. I could not stop it so I had to cut the cable from the keypad to the control panel. I rewired the broken cable but the keypad is dead, the pirs are all lit up. When I connected the live wire to the keypad it makes a very light ticking noise but no lights on the panel.
Any ideas...please. Thanks
Not necessarily, there could be a few more reasons too and if the battery is really old the charging circuit may be damaged.
If the battery was knackred and the mains is on surely the panel would still light up? Thanks
Nope, the keypad was never designed to be disconnected on a live panel, and I'd bet the NVM is corrupted, as it often is on this model.
It's a 9800 / 9800+ by the way, 9827 refers only to the keypad itself.
