Roger Fallon Posted December 30, 2018 Posted December 30, 2018 There are two small glass tube fuses in the top left hand quadrant of the circuit board, labelled F1 and F2. F1 is 1A quick blow, F2 is 250 mA quick blow. Sizes are 20mm long and 5mm diameter. Prise out of spring holder and check with eye or preferably with meter. In my case F1 was blown and gave the !!!!Check!!!! Low batt indication. The in-line Fuse in the positive battery lead can be unscrewed for visual check/meter check. if you need to change the battery, can be sourced from Quote
PeterJames Posted December 30, 2018 Posted December 30, 2018 I would hope after four years he would have fixed the fault by now Quote
Roger Fallon Posted December 30, 2018 Posted December 30, 2018 Yes indeed. Posted as people currently searching with this problem as I was. Quote
