I've not looked at Axis DVRs.
IP cameras are not the worst but no better than Hikvision.
Sorry, I meant the cams
Surprised at that as they seem to offer a lot of seemingly esoteric security / IPsec options.
Not that that makes them more secure by default, I know.
And I've never used Hik IP so can't compare.
And just to give you an idea of costs and time - it would probably take about 5 days of work for me to say "This DVR with this given firmware in this configuration is secure enough to be on your network" with any level of confidence.
If there all fitted to the same standard and specification, surely this would only need doing once for each model/firmware?
Again I would expect the manufacturer to have had this done externally.
I also agree with PJ about 1 and 2 being hard to implement on some networks.
Point 3 should be done as standard for anyone with knowledge of setting up firewalls, however, someone with a network background would understand this in more depth than an alarm monkey.
Yeah, they have a lot more functionality that should keep them secure, but they suffer from the same kind of issues (all running as root, vulnerable services, services you can't turn off etc) as the cheaper cams.
One manufacturer put such strong legal threats out to a researcher that he pulled research and a talk - he won't say who it is though.
I have a blog, some of which is about alarm security and reverse engineering:
http://cybergibbons.com/
Yes, it would need doing once per model at least.
