At some point I'm intending to put the works DVR on its own Vlan
I've a draytek 2630 & a 2626pwr procurve switch
I've never done one before, so was expecting to use the router ports as-
p1 all vlans
p2 vlan 2 (patch lead to HP switch)
p3 vlan 3 (patch lead to DVR)
p4 vlan 4 (not used)
the switch also supports vlan
should I need to access DVR from internal network I was intending just to plug the hp switch into p1 then back into p2 when finshed
  On 06/12/2015 at 11:22, PeterJames said:
My works has 5 public ip's so the CCTV can go on its own IP
I've 5 static ip's but would have delegate the router config to someone less "alarm monkey" ;)
Ah, but I thought (looking at the Draytek setup rules) the point was you could do this one way (internal network > DVR) without physical jigging about, but a hacker couldn't go from DVR > 'rest of internal network'?
