veritas 8
Guest justin
Alarm system works fine, except the strobe and external siren dont activate.
A walk test doesnt work either.
When alarm is activated internal sounders are going
The battey in bell box is fine as is the tamper switches
Any ideas
System is 1996, last service 2002
Could be a number of things
Faulty Bell
Faulty cable
Wrong connections
Not connected
Did it work when it was serviced?
Do the zone lights illuminate when walk testing?
If you don't know......ask.
Guest thanks for reply
bell worked fine until a few months ago
cable runs seem ok , lights come on thru tests
not sure if bell box ciruit tho
cheers
i fotgot to say the flashing led doesnt work either
thanks again for replies
the battery in the bell box is reading 8.1 volts , i assumed it was renewed at service.
Ill check the fuse
How do you reset after a timeout?
is there a fuse in the bell box?
27835[/snapback]
Not usually, it could be a faulty bell box or damaged cable. What voltage do you get at each end of the hold off supply in the panel and bell box?
