Hi
Just woundering if its ok to install a control panel within a kitchen area the fused spur would be mounted at cieling height from a cieling rose connected to the lighting for the house which is located within the loft space!.
The panel would be very clear of the surfaces within the kitchen but at an acceble height on the wall adjacent to the living room.
Also it's away from the cooker and any sources of steam like a kettle!.  It will be placed within a closed kitchen cabinet in the future would this be acceptable its's just in terms of the security and what the client wants it'd be the best place to install.
I understand that since 2013 kitchens were taken off from part P as special locations would this till be ok?
cheers
Id question why would you want to, but I suppose the answer is there isnt anywhere else. Kitchens will get damp occasionally, condensation from cooking and when the kettle goes wrong, not really a good place to put a bit of electronics that could cause a whole lot of noise should it go wrong.
so it's ok then?, or should i try push them to put it elsewhere?
I mean in my eyes it wouldn't cause any problems in practice does anything else you plug into a kitchen socket and leave have any troubles?
the oly otherplace I can put it that's practicle is in the entry exit route, then it means theres 30 seconds for someone to pull it off the wall
also its further away from the telephone connection, plus if they break that then it wont call out
If it's a 3 wire, why not?
No different to using it to connect a 500w floodlight.
Whether its done properly is another matter obv.
Posted (edited)
WTF? If it can't be dedicated, I always put the panel on the lighting circuit, even if it means extra work.
Lights either don't have RCD protection, or get fixed quickly. Sockets can trip and get left off for hours or even days.
Slightly less relevant now with all RCD boards I grant you.
The average panel takes less current than an standard 100W lightbulb.
Edited by datadiffusion
