Simlec Posted December 23, 2015 Posted December 23, 2015 On 23/12/2015 at 18:39, Flossyrockstar said: Yeah that what i thought, not on one of my jobs. Because its a lighting circuit! No, it's a 6 or 10amp radial circuit with lights on it.Taking the feed from that radial circuit for your panel via a fused spur is perfectly acceptable. Technically there's no need for the fused spur as this is only there to protect the cable not the panel hence panel manufacturers have there own mains fuse inside to protect the panel. Quote
datadiffusion Posted December 23, 2015 Posted December 23, 2015 (edited) Thought for a minute you'd thought I wasn't using a spur...! Re-read it now and get you. Exactly, it's a circuit like any other that happens to be mostly used for lights. What next, no TV amp in the loft? Edited December 23, 2015 by datadiffusion Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands
PeterJames Posted December 23, 2015 Posted December 23, 2015 Problem with using the lighting circuit is that when a bulb blows it takes a trip with it Quote
Simlec Posted December 23, 2015 Posted December 23, 2015 On 23/12/2015 at 20:40, PeterJames said: Problem with using the lighting circuit is that when a bulb blows it takes a trip with it Lol spend some of your money and get LED lamps Quote
datadiffusion Posted December 23, 2015 Posted December 23, 2015 (edited) On 23/12/2015 at 20:40, PeterJames said: Problem with using the lighting circuit is that when a bulb blows it takes a trip with itBut bulbs aren't usually on when the property is empty for a week...And thats a common cause, bulb blows, householder replaces, circuit back on. Whereas power circuit trips, cause unknown, owner shrugs shoulders, repair time variable. On 23/12/2015 at 20:44, al-yeti said: Rcbo on it own circuit? Thats fine, still often reset / resettable quicker than a power circuit trup. And fixed circuits mean few changes, more stability. No car boot battery chargers being added to circuit and causing random trips. Edited December 23, 2015 by datadiffusion Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands
breff Posted December 23, 2015 Posted December 23, 2015 Am I missing something? If the power is coming from the loft space, why cant you put the panel in the loft, or are you not using a remote keypad? Quote The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not)
