I would suggest it may be the alarm service timer, prob will require an engineer call out
I forgot they had that function
Posted (edited)
If the engineer has set the panel up for engineer reset on tamper & system is tampered it usually says "Service Due"
If it is service timer, usually warns 2 weeks before then says lock out, when you try & set it will say use code (4 random numbers) I think you can [...] & allow to be used for a further 2 weeks but ultimately think it will be an engineer call out..
Edited by datadiffusion
Public
Cant say I've ever noticed the service timer on a CP8,  Its deffo on a CPX but I'm certain the CP8 doesn't
So it does, Option 54 Service Timer.... I've never used it, Don't generally use built in service timers to be honest.
