How if at all do you get away with installing an optex IR beam within a premises linked onto a grade 3 intruder alarm?
I'm hoping to install the SL-350QDM as an added extra across a series of long roller shutters. It already has two contacts either side on all shutters but the customer has asked for additional protection due to the chance of cutting through.
I presume it doesn't comply as I've seen nothing in the data sheet to suggest otherwise.
I have read something similar that it can be done but cant trigger a confirmed activation?
Any help will do!
http://www.optex-europe.com/products/optex/185-sl-350qdm/
Posted (edited)
thought there wasn't such a thing? Ie g3 active beam (could be wrong)
What about elephant catchers down the Roller shutters?
We would normally contact the doors like you have, then have a DT across each one.
Edited by 9651
I dont believe there is one... I kind of pre guessed before posting but needed confirmation (whey)...
Yeah I think I may have a look down that route, surprising nothing is out there though, suppose the demand isn't there...
The Optex beams are grade 3
Any comments / opinions posted are my opinion only and do not represent those of my employer or Company
Where in the regs is that stated
