Either way not much stopping you from installing and then they can move it to what ever posistion they want , they normally do anyway
customer wants a camera to view across the road to watch their car at night, this view will have public footpath.
Is this OK?
CCTV used on your property will be exempt from the Data Protection Act unless you are capturing footage of individuals outside your property.
However, regardless of whether your CCTV system is exempt, the ICO recommends that you use CCTV in a responsible way to protect the privacy of others.
What if my camera captures footage of individuals beyond the boundaries of my property?
You must consider whether it is necessary for your camera to operate beyond the boundary of your property.
If your camera covers, even partially, any areas beyond the boundaries of your property, such as neighbouring gardens or the street, then it will no longer be exempt from the Data Protection Act (DPA) under the domestic purposes exemption. This does not mean that you are breaching the DPA but it does mean that you might need to take some steps to comply with it.
  • 2 weeks later...
