alarmcom Posted February 2, 2016 Posted February 2, 2016 Do you know what kit that is?E-writer pro. I have never used it. The unit plugs into a PC and the office programs the the unit with the reader type required. On site you hold the lead on to the reader and press the program button until the LED turns green which is seconds. The reader then works with the cards you require. It no longer recognises the existing card type.. The replacement cards are normally added in bulk by en- block adding Using a memory stick imported from excel this bit I do a lot. Quote
