paul73mt Posted February 7, 2016 Posted February 7, 2016 Sorry just to start off straight away with a problem but I'm pulling my hair out here and prohaps someone can confirm what I'm thinking. I today wired up my alarm all ran with new 8 core cable. So I have left them tamp circuits bypassed with the link in the main unit until I know it's right so to speak. Anyway the problem I have is that my bell box is making two different sounds when the battery link is not connected and time link is still on "test" it will sound as normal now when I put the battery link on it then seem to make another sound over the "normal" sound I have wired the bell box as it says in the Accenta book and checked wiring more than once, Also when I do a strobe test on the remote lcd keypad it works when I try the bell test I get nothing.Any ideas?? Thanks Paul Quote
al-yeti Posted February 7, 2016 Posted February 7, 2016 What connection have you made? Example strobe to -strobe etc Also take the bellbox down and wire it up next to the panel , it may help in you working out what you have done wrong , still possible its faulty of course Quote
paul73mt Posted February 7, 2016 Author Posted February 7, 2016 I have wired it all gen 4. Side strode - To. STB SCB (T) To. RTN (T) SCB (A). To Hold off - (A) Bell (D) +. To. Hold off + (D) Bell (B) - To. Trig (B) Quote
paul73mt Posted February 7, 2016 Author Posted February 7, 2016 just thought of one thing I haven fitted the battery backup in the main panel as the one I have got is faulty would this make any difference ?? Quote
al-yeti Posted February 7, 2016 Posted February 7, 2016 No battery shouldnt make difference, although faulty batteries can damage the panel You do realise test is just an approx 5sec burst and it will change when you take that off? Quote
paul73mt Posted February 7, 2016 Author Posted February 7, 2016 ok sorry to keep going on but did progress a little further. Thought I would take pictures of all the connections then work out what had gone wrong. Took picture of control panel and forgo hat I had connected the phone dialler so I though I would take off the trigger connection to the Bell - connection on the main panel. After doing this I tried to 'test' the bell output again. this time it worked !! So the strange sounds I were getting from the bell box could be because I was trying to reset but getting a trigger ?? so I'm hoping to reconnect the battery in the bell box tomorrow and then see what it does. Quote
al-yeti Posted February 7, 2016 Posted February 7, 2016 Sounds as though you wired the phone dialler or programmed it incorrectly who knows , sounds like allot of guessing Do one thing at a time Quote
paul73mt Posted February 7, 2016 Author Posted February 7, 2016 yeah maybe I should of but the instructions told me to do this but the newer panels now have a dedicated output where I was looking and a manual that only listed the ADE Accenta 6 but you live and learn. Just hoping it will cure he 'funny noise2 from the bell box when I reconnect I tomorrow . thanks for posting Quote
