Hi all.
Got a faulty adt fire panel which I need to find a compatible replacement for.
Could any of you suggest a replacement 4 zone panel?
Thanks Dan
post-30520-0-79057800-1455148482_thumb.j
post-30520-0-21074900-1455148512_thumb.j
Almost certain we replaced one of these with a ctec in the past. Conventional apollo detectors.
Hi all.
Thanks Dan
Is it the panel at fault or the system?
Its the panel at fault. Zone 1 had a fault last week and could not find any issue with the circuit. I then move the circuit to zone 4 that was spare and all was well. I then put a EOL on zone 1 and it still showed as fault. Now zone 2 has done the same.
