danlad1980 Posted February 10, 2016 Posted February 10, 2016 Hi all. Got a faulty adt fire panel which I need to find a compatible replacement for. Could any of you suggest a replacement 4 zone panel? Thanks Dan Quote
james.wilson Posted February 11, 2016 Posted February 11, 2016 Gaz? Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
whistle Posted February 11, 2016 Posted February 11, 2016 Almost certain we replaced one of these with a ctec in the past. Conventional apollo detectors. Quote
sixwheeledbeast Posted February 11, 2016 Posted February 11, 2016 I believe there just conventional too. Quote
Adi Posted February 11, 2016 Posted February 11, 2016 Hi all. Got a faulty adt fire panel which I need to find a compatible replacement for. Could any of you suggest a replacement 4 zone panel? Thanks Dan Is it the panel at fault or the system? Quote I really can't be ar**** with it anymore.
Shaunb1905 Posted February 11, 2016 Posted February 11, 2016 As above, are you sure it's the panel? Quote
whizzer Posted February 11, 2016 Posted February 11, 2016 I would say C TEC or SMS are just as good Quote
Shaunb1905 Posted February 11, 2016 Posted February 11, 2016 Used to use c tec but recently change to Kentec as had to many problems with the c tecs Quote
danlad1980 Posted February 12, 2016 Author Posted February 12, 2016 Its the panel at fault. Zone 1 had a fault last week and could not find any issue with the circuit. I then move the circuit to zone 4 that was spare and all was well. I then put a EOL on zone 1 and it still showed as fault. Now zone 2 has done the same. Quote
