Posted (edited)
Anyone know of a loop in/loop out coax to coax panel 16 way? I literally need to move 3 DVR's from a rack and the cables need extending so far, ideal solution would be to replace the DVRs with a patch panel with loop in and loop out?
Kind of thing attached but cant seem to see anything... BBV do a loop in then loop out x 5..... :S I literally need 1 x loop out per channel.
The pic does do the job but it is a protocol RS485 serial telemetry converter and is pricey for what's needed.
Any suggestions...
post-70076-0-98509500-1455657685_thumb.j
Edited by ElecTech
Adaptable box and some male BNC throughs would be my first thought?
Wanted to avoid that really, some kind of rack mounted patch panel would be a lot neater. I have done a few adaptable boxes and they soon become spaghetti junction no matter how hard you try to avoid, expecially 94 cams...
TP converter rack mount version
This is Ethernet? This is an analogue coax system.
Nvm... May have found the product...
http://www.haydonmarketing.com/product-hay-sp16cx.html
Kill two birds with one stone.
Why not use some of the 16ch rack mount to balun units, then you can use a few cat5's to your new location, rather than a massive bundle of rg59.
4 cams per cat5. its sill an analogue signal, and looks neat too. (and is a heck of a lot easier to run cable wise than your 94 runs of coax)
