ether8000
Guest smokie04
Guest smokie04
ok have ether800 dvr card with there software works fine for about two days
after that main program works ok and motion detection ok still saving video to drive
when you play the video that has been saved the seconds clock has stopped working on playback and when you try to return to main screen it crashes the program
up till this time playback works fine
Hi Smokie
I'm suprised Echo hasnt replied being the Ether8000 rep in this forum, I presume its the same cards :whistle:
Echos post, If you already have a solution please add it to your origional post as the forums are archived for knowledge purposes for others to make use of.
Guest smokie04
im not suprised didn't answer email and company didn't bother with a answer
so much for the card and support
Guest smokie04
update
company is now working on a upgrade to fix the problem been told a few days
will let you know the results in case anyone else has a problem like this with this card
