spuis Posted February 24, 2016 Posted February 24, 2016 Hi all, I have installed a honeywell galaxy flex V3 and everything works like a charm. While using it we are running into some trouble where hopefully someone can help: When the alarm is set and we enter via the front door, we would like the keypad to beep as a reminder the alarm is set. At the moment it remains silent and we forget the alarm is set, only to be reminded by a lot of noise after 30 seconds entry timer. Is it possible to have an audible entry timer? preferably from the keypad off course? Thanks, Mike Quote
al-yeti Posted February 24, 2016 Posted February 24, 2016 Keypads normally have a volume control to give you the tones and the speaker connection is for the internal sounder aswell as the entry tones and set tone Perhaps volume is set to off , what keypad is it ? It is possible you havnt set the zones up correctly aswell, front door should be set as a "final" zone type , but sound asthough you have no exit time either? Hence look at volume control Quote
whistle Posted February 24, 2016 Posted February 24, 2016 Check the Dd243 menu in parameters, I bet it's set to disable keypad during the entry time. It's defaulted to this if it's a Tyco panel. Quote
ElecTech Posted February 25, 2016 Posted February 25, 2016 Check the Dd243 menu in parameters, I bet it's set to disable keypad during the entry time. It's defaulted to this if it's a Tyco panel. Doesn't that just disable the buttons and not the tones? Pretty sure the volume controls are still active... Quote
Nova-Security Posted February 25, 2016 Posted February 25, 2016 Doesn't that just disable the buttons and not the tones? Pretty sure the volume controls are still active... As above, make sure the keypad is set to audible in the keypad menu Quote www.nova-security.co.uk www.nsiapproved.co.uk No PMs please unless i know you or you are using this board with your proper name.
rubble1977 Posted March 15, 2016 Posted March 15, 2016 Yeah check volumes had this once on a dimension when tones came defaulted as off for some reason Quote
