Hi all,
I have installed a honeywell galaxy flex V3 and everything works like a charm. While using it we are running into some trouble where hopefully someone can help:
When the alarm is set and we enter via the front door, we would like the keypad to beep as a reminder the alarm is set. At the moment it remains silent and we forget the alarm is set, only to be reminded by a lot of noise after 30 seconds entry timer. Is it possible to have an audible entry timer? preferably from the keypad off course?
Thanks,
Mike
Keypads normally have a volume control to give you the tones and the speaker connection is for the internal sounder aswell as the entry tones and set tone
Perhaps volume is set to off , what keypad is it ?
It is possible you havnt set the zones up correctly aswell, front door should be set as a "final" zone type , but sound asthough you have no exit time either? Hence look at volume control
Check the Dd243 menu in parameters, I bet it's set to disable keypad during the entry time.
It's defaulted to this if it's a Tyco panel.
Doesn't that just disable the buttons and not the tones? Pretty sure the volume controls are still active...
  • 3 weeks later...
