You've port forwarded to your own computer by the looks of it?? Port forward and the DMZ is set up for the IP 192.168.1.7....... and looking at the /ipconfig it seems 192.168.1.7 is your own PC? You should be port forwarding to the CAMERA address which is 192.168.1.8 by the looks on your settings!
Change the 7 to a 8 and it should work. But like above, also change to static...
Like I said forget the Samsung icon on the website it doesn't always work
For PC use smartviewer and phone use the samsungipolis app
i make the changes in the picture below and i can see my cameras frome the explorer
http://192.168.1.200
as in the pic
also feom samsung mobile app  i make the changes as the pic
and i can see the camera
the quation now if i go to another place so i will change me mobile network i think i will not see the camera
what i can change now to see my cameras frome any place at any network
Change your port forwarding and DMZ to the ip address 192.168.1.200.....
the ask now
i can see now on my computer on
192.168.1.200
and from mobile by samsung app
uf i travel now to another place will i see the cameras ?
if not
what can i change from the last picuter to see from any place ?
Put ipolis details in
Change to ddns
Put your device name you chose from Samsung after the /
Set port 4524
Set username admin
Set password to whatever you selected
Then turn WiFi off on your phone before trying to connect
