The only thing I can think to do is simulate a system using wire loops and test it that way.
If opening zone 2 triggers the other zones I know it's panel or programming.
But having 2 dodgy panels is almost impossible I think.
I'm stuck :(
agree with all of that.
I'm not missing a really obvious bit of progarmming at start up or something am I?  Or programming in another way than the default Programme 1?
I checked the setting on each zone and it was definitely 1 timed, 2 inhibit, 3-8 immediate.
No it isn't programming. Out of the box it wouldn't do what ur reporting. Prove the panel by disconnecting everything then once proved add things one at a time. One option would be to wire the rear door onto 2 and link 3 and follow the same process if you don't want to strip all the wiring
