Posted (edited)
Hi all,
We inherited this alarm from the previous occupants. It behaved itself for a good eight years or so but recently it's been beeping every half hour or so. If we key in a code we have it usually shuts up for another thirty minutes before starting again. If we don't do anything the beeping will become more frequent until its going every few minutes.
We seem to be able to access the full menu, but none of the immediately obvious menu options seem to work. I can't make head nor tail of the instruction manual.
Can anyone help? Is there a way to get it back to its old self?
Thanks!
Edited by Ash Mill
When it beeps and you put code in does it not display a fault or condition?
Or enter code press ent, ent, press a to scroll through menu as you said look for "display" scroll to log press ent and use a and b keys to scroll through and see what is displayed in last few events
PS cp38 is just the keypad , you probably have a large metal box somewhere and says galaxy something or other on it
If it's still in fault
Enter code and press ent it should say something like"status unset 01 events"
Press a and it it tell you what the fault in.
+CU/AC is a mains fail
Press ent and then esc to reset the system
